Steering wheel play
<strong>My steering wheel has developed a small amount of play in it. When centered, i can turn the wheel 1/2 an inch to the left AND to the right before the car actually starts turning. It feels loose in this 1inch are, but once past this area, it becomes taught.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is caused by wear on the rack of the 'rack and pinion' steering. Replace the entire unit - you can probably buy a rebuilt (Make sure its a Z28 ratio). You'll need an alignment.
If something else were loose, or the pinion was out of adjustment, the 'play' would be felt at all angles, not just on center.
DaveH
Matt
<strong>Tom, my car has almost 80k miles on it. ('98). And to the other guy...are you serious? Replace the whole unit? How much $$ should that run me?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My other car, a '94 Taurus, showed the same symptoms at 70K miles. As the rack spends most of its life in the center, that's where the wear happens. Take it to a local shop for a second opinion. I still haven't fixed the Taurus though...
DaveH
http://www.yfiles.com/NHTSA-1998-GM-...compliants.htm
