PLease Help....
Old Jun 15, 2002 | 02:23 AM
TravWS6's Avatar
Default PLease Help....
ok i got my Pro kit and im gona put it in tomorow night.. but i was looking at the parts i gota take off and so on.. how do i get the struts off?? the 4 bolts on top and 2 on the bottom of the shock right??? then how do i get it out? looses the top of the spindle?? and the most important question.. how do u get the 4th bolt on the dirvers side top strut.. its right under the master cylinder of the brakes?? do u loosen the cylinder?? i see the 2 bolts that go into the dash area under the hood.. or would it spill brake fluid every where if i loosen those bolts?? plz help asap! i barly get time to work on my car so i wana do it tomorrow or i gota wait a couple more weeks before i can touch it. Thanx soo much for anyone who can answer my questions.
Old Jun 15, 2002 | 11:39 AM
kent's Avatar
Default Re: PLease Help....
If you are replacing the front shock/spring setup, you take out a couple of nuts and move the brake lines out of the way--base on my memory--in order the the bolts on the top of the fender well to take shock off. I believe this was only the tricky part. hopes this helps.
Old Jun 15, 2002 | 01:49 PM
TravWS6's Avatar
that helps with most the questions.. but didn't answer the important one... on the drivers side fender theres 4 bolts... on my car.. 01 TA.. not sure if its different from other TA's but the the thing that holds the brake fluid (master cylinder) is right above the bolt..... how do i get the bolt out?? remove the master cylinder?...help help help
Old Jun 15, 2002 | 07:21 PM
TravWS6's Avatar
well this just sux.. whats goin on these days?? no one likes to help no more??? i got both front wheels off right now.. got the passenger strut off and i have one idea thats working to get that last bolt but its gona take forever.. and theres no way everyone has stock shox and hasn't done this before..
Old Jun 15, 2002 | 09:35 PM
kent's Avatar
On the drivers to take the shock off, you take off two nuts which whole the master cylinder and slide out of the way with brake lines attached. It is not necessary to disconnet any brake lines but just moved out of the way attached to master cylinder. After this you can take the two nuts off of the fender well to take the shock system off. This is way I did it on my 99SS. I hope this helps. If you any more questions and I can help, I will be glad to. Kent.
Old Jun 15, 2002 | 09:39 PM
kent's Avatar
By the way, there are only two nuts to take master cylinder to move out of the way. There are only two nuts to take off on the fender to remove shock. There are only four nuts to take off on the passengers side up under the hood to take the passenger side shock off.
Old Jun 15, 2002 | 11:41 PM
TravWS6's Avatar
Weell i got them in! haha just finished actually i figured the master cylinder just moves outa the way so i tried it.. thank god there was no brake fluid n e where.. thanx so much kent.. you have my respect <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> but i don't understand how some ppl couldn't just simply answer this question.. o well its done now. Thanx again kent <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
