Need help with rim width and backspace for SS
what's the widest rim and what backspacing that will fit onder my 02 SS. I have already desided on custom wheels but I'm having a hell of a time desiding wheel size. I am going to lower my car about 2 inches and I want to run 17s.I have measured the well opening three times and it looks to me that the widest wheel I can fit is a 9 inch wheel with a 7 inch back space( stock wheel dimensions).This appears to be the widest wheel that will actually tuck up inthe wheel well when the car squats. I would really like to go as wide as possible but I don't want a rubbing problem. I would appreciate any help you guys can give. Thanks, B
<small>[ June 23, 2002, 11:34 AM: Message edited by: BBWolf ]</small>
7.5" max in the front
that's without spacers... and if you plan on racing(autox, roadrace), some slight inner wheel well modifications in the back may be neccessary or buy a double rod-end panhard bar
<small>[ June 24, 2002, 09:21 AM: Message edited by: rollercam ]</small>
<strong>Are those back spacing # if so what is the max width rim and tire in the rear without rub?
Thanks, B</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">those numbers were for the backspace..
10.5" wide in the rear and 10" wide in the front should fit with only a small amount of problems using the backspacing i gave you
275/40's on 17x10s is a great wheel/tire combo
Front:
18" x 9.5", 58mm offset, 7.25" BS & 275/35ZR18 tires. Fit great, no rubbing anywhere.
Back:
18" x 10.5", 58mm offset, 7.75" BS & 295/35ZR18 tires. Require inner wheel well mods with a BFH. No outer wheel well lip problems at all. As a test right now running a 5/16" spacer, so mathmatically would be approximately a 50mm offset & 7.44" BS.
Hope that helps. Oh, and the car has been lowered about 1" all the way around and is on Bilstein shocks. E-mail me if you have further ?'s.
Andy
