front shock swap...HELP
Gary
I would think if you go a pair of standar coil sprinf compressors, with the bent steel hooks you would do better.
<strong>I used a standard coil spring compressor no problems. Not sure why you were having problems with the distance between the springs, even the ones from autozone will work fine. You want to make sure you use the coils that are farthest away and still get the compressor off when the spring is compressed.
Gary</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Gary, not sure which compressor you got from AutoZone but the ones we got were a piece of crap, after helping a friend install his we decided if we evey did this again we would just take the shocks to a shop and let them install the new ones for $20 (removed from car of course). Remember Dead guys can't work on cars .
Gary
