Trouble with brakes...
Old Jul 8, 2006 | 08:37 PM
azvforce's Avatar
Default Trouble with brakes...
I recently converted my 1995 Formula to the '98up Fbody front brakes. I switched everything and got it all buttoned up. My pedal goes to the floor, we bled the brakes a few times and it still goes to the floor. I bled them at the ABS unit and fluid came out like a cannon. When I do it at the caliper it does not come out nearly as fast.
I used C5 banjo bolts as the Fbody bolts were only available with the lines. I was told that the C5 bolts would work just fine. Could this be my problem? Are there any real differences in the C5 bolts versus the Fbody bolts? I know the C5 calipers are basically the same.
Thanks for any help with this.
