air ride
to drop 'em to the ground, does it require wheel well modification?
if you all know some good websits, i would appreciate some links also.
later
The only setup they make right now that may work on the front is their Shockwave shock (basically a Hal shock with an airbag in place of the coil-over spring). the only bad thing is that I do not think this will allow the car to sit on the ground (just not enough range of motion in this set-up).
I talked with Air Ride while I was on the Hot Rod Magazine Power Tour this year and they said they were in no hurry to make a kit for our cars (Mustangs already have a kit). However, they already had some rough ideas for it and said they should have one in a couple of years. My last bit of advice would be to find a reputable shop that does custom truck work. This is the scene that I hung around with before I got into F-bodies. There are some great truck shops out there that can put bags on anything that rolls.
If you want to do it yourself you still may be able to get some advice and ideas from the truck guys. I would really like to see someone do a top notch bag job on an F-body. Once everyone here sees the actually adjustability and control that bags allow, they will all be waiting in line. Bags are definitely more of an appearance upgrade versus a performance upgrade, but I have seen quite a few 400++ hp cars and trucks with bags and they all seem to do quite well. It all boils down to design and attention to detail. Good Luck!!
<small>[ July 02, 2002, 09:19 AM: Message edited by: rollercam ]</small>
I know this is an old thread, but I didn't see it anywhere so, here's a air ride front/rear kits for 82-02 F cars, http://www.ridetech.com/productinfo/airstrut.asp
