rear hal shock ?
Old Jul 8, 2002 | 12:49 AM
jcmccool's Avatar
Default rear hal shock ?
i installed hal shocks and hotchkis springs and now i am getting some rattles and pops that sound like they are coming from the rear of the car. i used the grade 8 hardware kit from Thunder Racing and put 3 washers between the shock and the lower mounting point. i had a friend that was helping torque the bolt to 66 ft/ls. i looked everything over today and noticed that the shock was touching the axle. should i add more washers or did i torque it down too tight. could something else be causing the noise?
thanks
jason
Old Jul 8, 2002 | 02:39 PM
acarnut's Avatar
Default Re: rear hal shock ?
I have a big cut-off saw, so I cut a nut in half to use to space the shock away from the axle.
DaveH
Old Jul 9, 2002 | 10:08 AM
mjf454's Avatar
I use the metal insert from a old set of shocks and cut it to size.
Old Jul 9, 2002 | 04:16 PM
jcmccool's Avatar
thanks guys
i ended up threading a nut onto the bolt between the shock and the mount. that let me torque everything down tight without squeezing the bushings too much.
