Cheap worthwhile brake upgrades?
Old Jul 10, 2002 | 11:57 AM
quickWS6's Avatar
Default Cheap worthwhile brake upgrades?
Are there any brake upgrades that are worthwhile without buying new calipers? Thanks in advance.
Old Jul 10, 2002 | 02:07 PM
SSilver's Avatar
Default Re: Cheap worthwhile brake upgrades?
you could get cross drilled and/or slotted rotors.
Also staineless steal brake lines and better brake pads.
Old Jul 10, 2002 | 02:28 PM
mitchntx's Avatar
The drilled and slotted rotor as a performance upgrade debate continies ... <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Right from BAER's website........
http://www.baer.com/faq.shtm
Although there are some companies which sell cross-drilled rotors as an actual performance upgrade, in our extensive testing we have seen no improvement to be had by simply crossdrilling stock rotors ...
... In racing, crossdrilling was designed to alleviate a problem known as out-gassing. In some of the older pad compounds ...
... Although Baer offers crossdrilling as an option on their systems, it is offered as a cosmetic option only ...
Now ... to answer your question ...
Cheap upgrades ????
Do a complete brake system flush with Ford HD truck brake fluid. It's ~$4 a bottle and 3 bottles should do the whole su=ystem.
Next, pads. Ask yourself ... Do I mind cleaning brake dust off my car? As you increase in performance on brake pads, they will increase the amount of dust generated. It's just the way it is.
For the street, I've never felt brake pad fade with OEM pads. I've felt the OEM fluid boil, but never pad fade.
Finally, rotors ... Autozone rotors made by Aimco work really well, even under EXTREME conditions. I've seen the crack, but have never felt or heard of the warping. And at ~$40 each, you can't beat that.
HTH
