Bad spring or shock?
Thanks
i'd say that you have a bent A-arm or something like that
i suggest finding a friend that can put it on a level lift at a body shop and take some measurements for you.. check the k-member.. and check the lower A-arm as much as possible
i bent my drivers side lower a-arm about 1/2" and it really screwed up the ride height of the entire car
good luck
