anyone with a hurst roll control???
It will not affect your ABS. Why that is listed I have no clue.
Bleeding the front brakes is the only part that really sucks. If you install the switch in the ash tray, it should be a very easy and straight forward install.
The lines were bent perfectly.
The only problem I had was with the connector for the hot wires and I had a sealing problem on one of the connections.
I had to take the roll control out and put itin a vice and set the line where I wanted it, then cranked it down.
2.5hrs or so. Another 30-45mins to set the button where I wanted it.
I put the button right on top of where you put a cigarette out. It fit perfectly and looks very clean. I used an die grinder to grind the side of it so the button would sit flush.
