brake bleeding question...
Old Sep 1, 2002 | 12:45 AM
1badvr4's Avatar
Default brake bleeding question...
if i took off the front calipers, and left the rear calipers untouched, do i need to bleed all 4 brakes, or just the front 2? tia...
Old Sep 1, 2002 | 03:36 PM
mitchntx's Avatar
Default Re: brake bleeding question...
When you crack open a bottle of brake fluid, it has almost a ZERO shelf life. So use up the whole bottle when bleeding.
To answer your question directly, I believe you will be OK just bleeding down the fronts.
Get a turkey baster from your local Wal-Mart for $.99 and remove as much fluid from the master cylinder as possible. Then re-fill the cylinder with fresh fluid and bleed till the fluid is clear.
