Help with suspension work, please!!!
Old Sep 16, 2002 | 03:53 PM
01ragtop's Avatar
Default Help with suspension work, please!!!
Well my car is a 01 A4 vert with a vig2800, cut out, G2 lid, FRA, TB bypass, nitto's, and a SLP ory pipe. At this time I have no suspension work done at all. I am able to cut 1.76 60' times and I am running mid 7.9's in the 1/8.
My question is what would be the best way to go on suspension mods? By the way not only do I not have any suspesion mods I also don't know anything about suspension.
Please enlighten me on the subject.
One more question. Will suspension mods lower my ET?
Thanks, Larry
Old Sep 19, 2002 | 12:05 AM
talonis's Avatar
Default Re: Help with suspension work, please!!!
I'd consider putting on some HAL adjustable shocks and front springs. I'd also replace the torque arm and maybe the panhard and rear LCAs. That should eliminate wheel hop and keep you firmly planted on the ground. You should see slightly better times I'd think. Might be a little overkill for your mods though.
