Brake rotor question?
Old Sep 21, 2002 | 06:45 PM
LARRY01Z28's Avatar
Default Brake rotor question?
what is the difference between cross drilled and slotted rotors? which would be best for drag racing and street use?
Old Sep 21, 2002 | 08:11 PM
LARRY01Z28's Avatar
Default Re: Brake rotor question?
TTT
Old Sep 21, 2002 | 08:43 PM
98_1LE's Avatar
Cross drilled rotors are lighter, weaker and they look pretty. Slotted rotors are also slightly lighter than blanks, are as durable as blanks and may enhance braking performance. Drilled rotors will crack if driven hard.
Old Sep 21, 2002 | 09:08 PM
LARRY01Z28's Avatar
Thank you very much. so for dragracing i should get cross drilled rotors.
Old Sep 21, 2002 | 09:40 PM
mitchntx's Avatar
I was noticing in JEGs that Wilwood makes a lightweight kit designed for drag racing.
I doubt you'd want to run it on the street ...
