Tire Pressure
Old Sep 23, 2002 | 03:45 PM
lastSS's Avatar
Default Tire Pressure
What pressure should I be running. I am at 24 right now. I think that is a little too low. Any help is appreciated.
Old Sep 23, 2002 | 04:13 PM
OBSSSD@work's Avatar
Default Re: Tire Pressure
Try 32F and 26R if you street race the car - and rotate your tires often!
Old Sep 23, 2002 | 05:48 PM
Blue Fire's Avatar
Well i belive. for the car you should do this. i been running 35 PSi in front and the back. but now my Nitto's are wearing just a little to much in the middle of the back tire's. i think you should try 30 PSi all the way around OR to 32 PSi all the way around... i been trying to get in touch with Nitto all dam day and can't get a hold of them.... i'll be putting my new set on soon after it get's out the shop. if i was you bud i would not run 35 PSi in them. that's a tad to much seems... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" /> heeh dont feel bad im still looking for the right PSi...
Old Sep 23, 2002 | 06:15 PM
WILWAXU's Avatar
Moving to Handling & Braking section.
Old Sep 23, 2002 | 10:09 PM
GregP's Avatar
Tire pressure will depend on the tire. Stock F1's? Go with 35 front and rear for street.
Softer tire, like Nitto 555's? Go with less. I'd try 32 both ends for the street and go to a track day to find out for the track.
Your handling on a track will tell you. Start with equal pressure front and rear.
If the car oversteers (loose, back end comes around), drop a couple of pounds in the rear on the outside that is loose. If the car understeers (tight, front won't turn fast enough), drop a couple of pounds on the outside front that is tight.
This assume youn start with enough pressure to not be underinflated to start with.
Once you know the offset for that track (you KNEW there was reason to practice and wear out all those tires, huh?), then try adjusting the overall pressure up or down a couple of pounds at a time until you know the correct setting by the handling.
Usually, a track will have more turns one way than the other, so you usually don't wind up with the same pressure in both sides at the same end of the car.
For street, run 35 in both ends, both sides until the wear pattern becomes apparent, then adjust. If it wears in the middle, drop a few pounds and start again. If it wears on the edges, go up a few pounds and start again.
I run 35 all around on the street with the stock Goodyear F1's and I rotate every 300o miles. Wear is completely even at this time .... On my track tires, I run 2 pounds less in the rear than front, and two pounds less in the right rear than the left rear.
Your mileage may vary.
