ARP Wheel Stud Question
I'm guessing my aftermarket lug nuts (closed end) will not seat against the wheel with these longer studs, so what are my options.
Will stock lug nuts work (open end) and the caps still screw on or do I need to find some longer lug nuts (closed end)?
Suggestions?
Just to double check with you...they will work on both the back and front, correct?
Just asking 'cause I know there's a little difference in how much thread is available between the front and back. I guess this pertains more to the lug nut covers.
Thanks
