adj. PHB???
Old Oct 3, 2002 | 05:39 PM
Evil SS's Avatar
Default adj. PHB???
I have the SLP Level 1 kit just sitting on my floor, and before I install it, I want to change everything. I'm going with Hotchkis control arms, and phb, but will I need an adjustable one? The kit only lowers the car 3/4" Thanks! <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
Old Oct 4, 2002 | 12:00 AM
Dope's Avatar
Default Re: adj. PHB???
Any change in height means adjustable panhard.
Dope
Old Oct 4, 2002 | 07:28 PM
acarnut's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Evil SS:
<strong>...will I need an adjustable one?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Maybe. 1) Cosmetically, you can center the axle left-to-right under the car. More importantly, you can 2) adjust the axle left-to-right for fender/wheelwell clearance. If you do 1) without checking 2), you may *create* clearance problems.
If you have the SLP level 1 kit, why would you buy Hotchkis control arms? Poly-poly LCAs create handling problems.
I run a 2.5" drop, a GM 1LE PHR, and 10.5" wide wheels, and the axle is centered and the tires fit up inside the wheel wells without rubbing.
DaveH
http://member.newsguy.com/~acarnut/
Old Oct 10, 2002 | 01:33 PM
Fulton 1's Avatar
My Eibach ProKit springs dropped me 1-5/8" in the rear and I was only off-center by ~1/8" with the rear axle. With a 3/4" drop you may not need any adjustment at all.
