G2 suspension: poly vs. heim
If you don't race your car (other than straight line), changing to poly/poly won't make a dif you can notice.
Before you change, make sure all the jam nuts are tight, and try again. And the rod end should be on the axle with the poly end on the frame... some ppl install them wrong.
The first mods I did included the poly/poly arms and that took car of wheel hop on acceleration.
And for feedback: Why don't you autocross or road race??? It's to much fun, and will teach you a lot about your car. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
It may not be as bad as a stock Trans Am or Z28... I've never riden in one with stock arms. But it was there for me.
The poly end should be on the body side (rod end on axle), but this is mainly for noise isolation. Don't think there's a performance benefit either way. FWIW, I did not see any reference to LCA orientation in my LG instructions.
<strong>chev4life,
The poly end should be on the body side (rod end on axle), but this is mainly for noise isolation. Don't think there's a performance benefit either way. FWIW, I did not see any reference to LCA orientation in my LG instructions.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have it this way and I have zero noise. Rod/poly is awesome. I never even regreased the poly side either. I had this for a few months now and I drive around Chicago. The potholes are in abundance here. I've beed to most states and the roads here are by far the worst. I also have poly endlinks/bushings, poly TA bushing, and poly trans mount. I was told I'm going to have horrible noises, but I'm not hearing anything. I also have very stiff 1LE shocks/springs. Car is stiff and nothing is making any noise.
Maybe you need to exchange the rods for new ones? Talk to LG, maybe they can exchange the rods.
<strong>From what I have heard the rod end is suppost to go toward the pass side of the car...ie the frame side...is this wrong? I think the G2 instructions said this. That is how my is installed, but if its better the other way then let me know and I will flip that sucker tonight.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's the only way the G2 Panhard fits. There is a shoulder bolt on the passenger side and the bushings are sized accordingly.
The LCA's go in poly to body, rod end to the axle.
