Which LCA relocation brackets??
Old Oct 17, 2002 | 07:37 PM
Sniper33's Avatar
Default Which LCA relocation brackets??
I've got BMR LCA's and I'm dropping my car 1" with 18" wheels on the rear. What brand relocation brackets should I get??
Old Oct 17, 2002 | 08:15 PM
raffi's Avatar
Default Re: Which LCA relocation brackets??
ummm if you didnt know.. BMR makes relocation brackets that you can get at thunderracing.com
Old Oct 17, 2002 | 08:29 PM
DARK AGE 53's Avatar
Get the BMR bolt-on kind.
Al
Old Oct 17, 2002 | 09:13 PM
Jake99SS's Avatar
I'm thinking about getting some Spohn weld-in brackets. The holes are drilled in an arc that follows the LCA as it swings down. I don't think any of the others I've looked at have that.
Old Oct 17, 2002 | 10:47 PM
Quickin's Avatar
What do these things do?
Do I need them, check my sig.
Old Oct 17, 2002 | 11:35 PM
Postal's Avatar
Quick, by lowering the car your changing the pinion angle on the rear. By using the relocation brackets after you've lowered your car. You set the right pinion angle. This allows the tires to bite down like they should. By lowering the car, the car fights more for traction and sometimes gets wheelhop.
