Install Problem on Rear Rotors
Old Jul 19, 2006 | 07:07 AM
BoneSS's Avatar
Default Install Problem on Rear Rotors
I installed some cross drilled/slotted rotors, and took the car out for a test run. Now I posted before that the drum part of the rear (not found on the front) for the e-brake caused me some problems as it did not appear to want to fit. It sounds like something is clanking behind the rotor whenever I drive the car (not just under braking) but it is intermittent as it seems to do it under both braking and nonbraking, but it is not constant.
