Traction problems.....
When I get on my car it has bad wheel hop. Thought it was the lowering springs, but later put back the stock springs and added some BMR LCA's. Helped a little but not much.
Went to the track. Launching is fine, but right when I hit second gear the car gets squierly like a **** and the rpms shoot up and hit red line before I can do anything....
Does anyone have any advice???
On the street the car makes a clunking noise when you get on it on first and second gears.... Sounds like wheel hop, but my friend said it might be the torque arm???
Please help! Did not experience this problem before the headers and the lowering springs... Also I installed the lcas witht the greasing area toward the rear of the car. Is that correct?
Also is there a way to set the pinion angle back to stock... Someone said that might be it too
Thanks!
<small>[ October 27, 2002, 04:05 PM: Message edited by: Str8crusinT/A ]</small>
