Help me choose
Springs - Hypercoil's
Shocks - SLP Bilstein's
Adj PHR - G2
Now I need help choosing LCA's and brackets. I had intended to use G2 LCA's, but I want to use bolt in brackets (G2's are welded). And due to some fitment issues, I do not want to mix'n match manufactures.
So... I like the look of Metco's LCA's. Are Metco's bracket's bolt in? Can someone explain to me pro's/con's between boxed and tubular if any.
Any other idea's?
TIA. Scott.
for profromance you cant go wrong with BMG..
HOPE THIS HELPS YOU OUT.
Anyone know if the Metco brackets that come with their LCA's are bolt in?
Scott.
