need some help...
Old Dec 7, 2002 | 01:02 PM
unfcamaro's Avatar
Default Re: need some help...
Thanks again. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Dec 8, 2002 | 12:19 AM
unfcamaro's Avatar
Default need some help...
I just bought an SLP stb used. The bar is in good shape but didn't come with the mounting hardware. Does anyone know what I need to install it, what size bolts, nuts, washers, etc...
Old Dec 8, 2002 | 12:27 AM
DARK AGE 53's Avatar
There isn't any mounting hardware, you just remove the four nut's ( two on each side ) on top of your shock towers. You use the same nuts, I think the torque is something like 35 ft/lbs... I'll see if I can't check on that.
Al
Old Dec 8, 2002 | 12:33 AM
unfcamaro's Avatar
Darkage: Thanks for the help! I really didn't want to have to wait until Monday to call SLP
Old Dec 8, 2002 | 12:34 AM
It's 32 ft/lbs, to torque the inside nut's we used a Crow foot wrench, if you don't have a torque wrench just tighten them down good and tight... don't go crazy. You want the car sitting on level ground with the weight of the car on the suspension.
Old Dec 8, 2002 | 10:11 PM
trackbird's Avatar
Stick a washer under those nuts (stainless if you have them available) to help keep the nuts from chewing into the STB (when you tighten it, or over time). Just a thought.....good luck
