getting more adjustment for alignment?
Old Jul 26, 2006 | 11:03 PM
hallass's Avatar
Default getting more adjustment for alignment?
i lowered my z with sportlines about a month ago, and just got around to aligning the thing today. this is the second f body that i've put sportlines on and neither of them had enough adjustment to get the caster/camber in. i got the camber close, but ran out of adustment, and the caster is still about 2 whole degrees out. i'm thinking about taking a dremel or die grinder and elongating the adjustment slots a little longer to try and get them in, but i figured i'd see if anyone has tried anything else first. i'm pretty sure i've seen an aftermarket upper control arm somewhere with some adjustabiltity to it, and may try that if noone has any other ideas.
