When changing brake pads...?
Old Jan 9, 2003 | 02:37 AM
my2kTA's Avatar
Default When changing brake pads...?
When changing brake pads, do i have to have the bleeder valve open to push back the piston? My father told me I may need to in order to prevent damaging the abs module.
Or can i just go ahead and push it in normally with out the worry?
Old Jan 9, 2003 | 05:42 AM
DARK AGE 53's Avatar
Default Re: When changing brake pads...?
Over the years I've changed quite a few brake pads and have never opened the bleeder valve.
Al
Old Jan 9, 2003 | 08:15 AM
mitchntx's Avatar
Neither have I.
However, forcing the old fluid out of the caliper through the bleeder screw as opposed to back into the lines is probably not a bad idea.
Old Jan 9, 2003 | 02:08 PM
talonis's Avatar
GM states you should open the bleeder. I would recommend that you do, in theory you could force contaminents into your ABS system which could cause complications.
Old Jan 9, 2003 | 03:05 PM
my2kTA's Avatar
Thanks, Ill be sure to do that when i change my brakes tonight <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
