How to remove front sway bar?
Old Jan 16, 2003 | 02:35 PM
Loudmouth LS1's Avatar
Default How to remove front sway bar?
I would like to remove my front sway-bar, anyone have a walk thru on how to do it, and is it hard to do? I would assume it should be pretty easy, doesn't seem like there's much to it. Thanx guys
Old Jan 16, 2003 | 09:25 PM
2000WhiteZ28's Avatar
Default Re: How to remove front sway bar?
Remove end links, use some PBlaster or WD40 on the threads first to avoid twisting them. Remove two bolts on each bushing bracket. Some models have a bracket that cradles the driver side bushing. Take off the nut underneath and two screws inside the wheel well to remove the cradle. I really don't recommend driving around town too much with it completely removed as it does seem to hinder braking and makes the front end very bouncy. Enjoy.
Old Jan 17, 2003 | 01:24 PM
Thanks!
