hal shock questions
<strong> you can use any spring. but if you use a syock style spring and not the HAL spring you have to cut the bottom pearch off a stock shock and put on the front HAL so it will have something to sit on. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep, MMI Z28 is correct. Did it myself this past weekend with Eibachs.
Here is a link that I found that explains the installation of the shocks and modification of the stock perches.
Hal shocks with Eibach Pro-kit installation
