How to adjust LCA?
Old Feb 13, 2003 | 11:26 AM
ls1z01's Avatar
Default How to adjust LCA?
I got some new adjustable LCA and my question is before everything is tightened down how do i know the left and the right LCA are identical lengths? Should i adjust it to the smallest length possible? Thanks for any reply in advanced! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 13, 2003 | 02:00 PM
Phil99TA's Avatar
Default Re: How to adjust LCA?
Get a stock LCA, and lay them side by side, adjusting the new one until the holes line up. Get a long bolt to go through both, that way you can line them up perfectly.
Old Feb 13, 2003 | 02:23 PM
2001CamaroGuy's Avatar
I second Phil99TAsoon.....
Old Feb 13, 2003 | 02:41 PM
DARK AGE 53's Avatar
I agree with you guys, but I've always wondered why anyone would want adjustable LCA on a street driven car?
Al
Old Feb 13, 2003 | 04:40 PM
ls1z01's Avatar
i did that but since my lca is rod/rod ends i feel like there is quite a area of play as the bolt goes through the lca should i tighten it (shortening the lca) after i bolt it on the car and that way htere is no more play between the rod end and the frame of the car?
<small>[ February 13, 2003, 04:43 PM: Message edited by: ls1z01 ]</small>
Old Feb 13, 2003 | 05:48 PM
SSixspeed's Avatar
Or take it and get a thrust angle alignment done on it.
