12 bolt ?'s
Old Feb 25, 2003 | 01:33 PM
last of the Z28's's Avatar
Default 12 bolt ?'s
a got a 2002 z28 thats stock.if i get a 12 bolt how many channel abs do i need?thanks
Old Feb 25, 2003 | 02:21 PM
CamM's Avatar
Default Re: 12 bolt ?'s
3 channel = ABS only rear
4 channel = ABS with ASR/traction control rear.
Depending on what you have stock is the channel that you need.
Old Feb 25, 2003 | 02:27 PM
i dont have traction control.can a 4 chanel still work?what mods would i need to make it work?
Old Feb 25, 2003 | 03:56 PM
rodent's Avatar
I think it would be difficult to get it to work since the 4 channel has the sensors at each wheel on the backing plate and the 3 channel sensor is close to the pinion. Might call Moser and see if you can add the pinion sensor.
Old Feb 25, 2003 | 04:02 PM
so much for that idea.i had a used one (maybe)lined up somewhat locally at a good price with the gears i wanted but its a four channel setup!!!damn it oh well....back to the drawing board.
