Brake Rod
It's a 98 Z.
Thanks !!!
Beth
<small>[ February 27, 2003, 04:21 PM: Message edited by: Beth ]</small>
What are you trying to do? (just wondered what you needed the specs on the rod for...). I'd check with your local dealer, see if they have one on the shelf, take calipers and ask if you can measure it. Plan B, if it is not that expensive, order one, measure it and toss it in your tool box. Third idea, junkyard, or see if a parts store has a brake booster with pedal rod on the shelf (not likely...but you can try). You may be able to get your answer one of those ways....good luck.
