Suspension for Auto-x???
My vote would be Koni DA dampers, Eibach Pro springs or a set or GC coil overs with whatever your desired spring rate would be, a ST 35mm front bar, 19-21mm rear bar, adj. LCAs with rod ends, adj. Panhard Bar with rod ends, adj. tubular control arms, a set of SFCs, maybe a tubular K-member, set of 315/35/17 Hoosiers and most of all-A CRAPLOAD OF SEAT TIME!
How bout that? My wish list anyway. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
F-stock is usually a good place to start, but may not be realistic for you. I ran one season in F-stock but then when I got my new car I had to mod it. I will be running in ESP this year. I have my mods listed on my websight. The things that aren't installed yet, but are coming in the next couple weeks are an Edelbrock Torque Arm, 1LE lower control arms, Torsen T2R differential, 5 point harnesses and a harness bar. I'll be running on 275/45/16 Hoosiers.
This is what I would do, in order:
Seat Time
Harness
Seat Time
Any of the above
Seat Time
More of the above
Seat Time
After you go out a few times, and find out what the competition is like, and the rules on what mods you can have for what class, then form a plan.
Glad to have another convert <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ March 14, 2003, 01:25 PM: Message edited by: SSmokem02 ]</small>
