How to delete ABS
Old Mar 18, 2003 | 10:07 PM
trackbird's Avatar
Default Re: How to delete ABS
Pat, If you remove the ABS, you will need to create some type of proportioning valve to control the rear brakes. As I remember, the rear brakes are controlled by the abs module in some fashion (I'm not sure if there is an actual proportioning valve or if it just uses the ABS to control the rear brakes)...I've not looked that far into the system as of yet. You may also have computer issues and you may want to put a post in the PCM Daignostics and tuning section to see if anyone knows anything about removing the ABS function from the ECM. Good luck!
Old Mar 19, 2003 | 12:20 AM
AndUAndI's Avatar
Default How to delete ABS
How is this done? Want to remove the ABS modulator. Seems like it could be accomplished with a couple of T fittings.
What size are the fittings on the ABS modulator?
BTW, this is a 4 channel system and I'll be adding line lock when I do it.
Saw one post from Pain, but the picture link is gone.
Thanks in advance.
Pat
Old Mar 19, 2003 | 08:41 AM
AndUAndI's Avatar
No ABS on the car now (effectively). The rear is a 9" and as built has no provisions for ABS rotation sensors.
