koni / bilsten combo ? please help
The konis are probubly some of the top shocks around (EXSPENSIVE!!!!! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> ).
You said you don't want to lose straight line traction....the reality is ANY lowering (stiffer springs) will have a negative impact on traction. The stiffer the springs (lower you go), the worse it will get (loss of weight trasfer). You can always put wider tires on to make up for the loss but you will probubly notice the car won't hook as well after the spring swap.
Remember, you will need an adjustable panhard rod if you are going to change ride height. The panhard rod centers the rear under the car. I always vote rod ends on everything (far better preformance). I would suggest you get one of these first.
Chris
<small>[ March 28, 2003, 05:53 PM: Message edited by: GM ]</small>
