Correct way to weld in subframe conn.?????
Old Mar 31, 2003 | 01:07 PM
2FAST4U's Avatar
Default Re: Correct way to weld in subframe conn.?????
Your suppose to use a 4 post lift so the wheels hang, weld the hell out of them and thats it!
Old Mar 31, 2003 | 01:18 PM
striker754's Avatar
WRONGGGGGGG
You want the suspension loaded. Use a drive on lift or four ramps.
Old Mar 31, 2003 | 03:56 PM
2001CamaroGuy's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2FAST4U:
<strong> Your suppose to use a 4 post lift so the wheels hang, weld the hell out of them and thats it! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">OMG NOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
You want the tires sitting on the ground/lift/stands/....something so the suspention is loaded and the car is sitting "naturaly". If you lift the car up off the tires, you rish putting twist in the body and once the subframes are welded you are in trouble. The car will never be straigt again (unless you cut the welds and start over)!
Chris
<small>[ March 31, 2003, 06:42 PM: Message edited by: 2001CamaroGuy ]</small>
Old Apr 1, 2003 | 12:50 AM
ls1formula99's Avatar
Default Correct way to weld in subframe conn.?????
Hi, what is the correct way to weld in subframe connectors, tak them in place with the car on the ground before lifting to finish??? Or can you lift then weld?? Thanks Ryan
