bump steer kit
How do they actually work? What does it change in the suspension that eliminates or reduces the bump steer?
After installing HALs, Eibachs, and new wheels/tires I have a bad bump steer problem and the car almost feel "unstable". I did have an alignment done and it was set back to stock specs.
Will going with diferent alignment specs help at all or will it make the problem worse?
They set it back to what ever the factory specs are, I remember looking at the print out that they gave me and it had what the factory recomended specs were and then what they set the alignment at and all the specs were right on.
I have the Pro Kit but I am not positive on how much it lowered the car because I also have the HALs so they are height adjustable. It is more than 1.5" though.
What does the bump steer kit actually do and how does it work?
