LCA bolt torque specs.
Old Apr 11, 2003 | 09:48 AM
Mike 01WS6's Avatar
Default LCA bolt torque specs.
What are the LCA bolt torque specs. I'm installing G2 Poly/Rod adjustable LCA's and I don't know the torque of the bolts, or if they are to be torqued at all. Thanks
Old Apr 11, 2003 | 09:57 AM
Vector-Z's Avatar
Default Re: LCA bolt torque specs.
They definitely need to be torqued. The specification is 87 lb ft for the LCA bolts.
Old Apr 13, 2003 | 11:26 AM
Mike 01WS6's Avatar
Really. I already got them in there this weekend but i used a different source for the torque specs. they said 80lb/ft. looks like i'll be under there next weekend torquing it up. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Apr 13, 2003 | 05:36 PM
DARK AGE 53's Avatar
Factory specs are 80 ft/lbs if you're torquing the head of the bolt and 60 ft/lbs if torquing the nut end.
Al
Old Apr 14, 2003 | 10:22 AM
Vector-Z's Avatar
I'm assuming your 01 WS6 has the same LCA specs as my 01 Z28. I got that specification from the 01 Camaro Helm's manual. In cases where I'm not sure of or don't know the correct torque required, I just call a chevy, or in your case a pontiac service center and ask. Some service centers don't like to hand out information, so just call around. Just trying to help. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Brian
