Front End Alignment Specs??
Old Apr 24, 2003 | 07:47 PM
vetteemt's Avatar
Default Front End Alignment Specs??
Ok I’m putting on a pair of Global west upper a-arms and a set of adjustable LG motor sports lower a-arms. After this I’ll need the front end re-aligned, so my question is what are a good set of specs to set the front end to? Take in mind I drive the car daily about 70 miles round trip, but also autocross on weekends.
Old Apr 24, 2003 | 08:04 PM
trackbird's Avatar
Default Re: Front End Alignment Specs??
This may be helpful....
https://ls1tech.com/ubb/ultimatebb.p...;f=25;t=002442
and....
https://ls1tech.com/ubb/ultimatebb.p...;f=25;t=002423
Good luck....
Old Apr 24, 2003 | 08:36 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
I'll be doing an alignment on my 02 WS6 tomorrow in my auto class. The suspension, wheels and tires are all stock. Can anyone recommend any specs for me?
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Rob
Old Apr 24, 2003 | 11:37 PM
trackbird's Avatar
Rob,
Depends on what you are trying to do. I get good tire wear with my current setup (20500 on the factory tires) and 8000 or so miles on the alignment and still have 1/2 tread or better left. For street, I'd stick to about .8-1.0 degrees negative camber, a "stock" castor setting (or 4.5 degrees works well) and 0 toe (not in or out). It's not too aggressive, but will inprove handling. Just my thoughts....
Old Apr 25, 2003 | 10:49 PM
BMW ///M Nerd
Thanks a lot man. I didn't have time to setup the alignment machine today, all I had time for was to rotate my tires. Too many kids kept asking questions about my car. <img src="https://ls1tech.com/threads/images/graemlins/grin.gif" alt="" /> I'll get it done once I get back from vacation though. Those numbers look great BTW thanks a bunch.
Rob
