Line Lock Question
Old Sep 6, 2006 | 10:04 AM
supersix's Avatar
Default Line Lock Question
I just bought a 95 Z28....It has a line lock on it. I am wanting to put the line lock on my 02 Camaro. Will it work on my car or are the slienoids different? And where can I order the steel lines?
Old Sep 6, 2006 | 11:05 AM
SJM Manufacturing Inc's Avatar
You cannot transfer them over, the ABS modulator has a different size fitting on it. The solenoid used doesn't matter...you can use any one on any car.
Depending on the solenoid you have, we can provide you with the lines that you need. We have pre-formed lines for a various solenoids. Visit our braking section on our website to see a variety of setups. Kits are in stock ready to ship.
Old Sep 6, 2006 | 10:27 PM
michaelg589's Avatar
what size IS that brake line in to the ABS module by the way? I really hope its 3/16
Old Sep 7, 2006 | 12:02 AM
supersix's Avatar
He said it was a TCI line lock......do you have the LS1 pre-bent lines to fit this slienoid
Old Sep 7, 2006 | 06:30 AM
Unfortunately, we do not make lines for the TCI solenoid. We've covered just about all of them but this style...A new kit may be your best option.
I'd recommend our B001 kits which are 125.99 which include the solenoid, a remote mount LED indicator, master arm switch and control switch with all necessary pre-formed lines. Everything is included...even a grommet for the firewall. No Teflon tape is necessary...parts come pre-assembled.
Michael, 3/16 will work BUT you need to create BUBBLE flare connections, not double flare for connections for the stock components. If you're trying to make your own, if you have the lines, bubble flare tool and misc fittings, this may be an option for you. You'll find that if you have to go out and purchase the supplies, it will cost more then our line kit which is ready to go.
