Wheel Hopping.......
Old Sep 8, 2006 | 02:02 PM
nseldy's Avatar
Default Wheel Hopping.......
What is the best solution for wheel hopping?
-lower control arms?
-torque arm?
-panhard bar?
-a combination of all three?
Currently I have the stock 275/40 Eagle tires. For right now I don't mind if the tires spin because I also still have the stock rear, but I'm just tired of the wheel hopping under hard acceleration. I guess I'm just looking to fix the problem without buying crap I really don't need.
I've read the stickies and polls and still can't decide on what to go with. Thanks everybody
Old Sep 8, 2006 | 02:38 PM
DONAIMIAN's Avatar
Relocation brackets->Control arms->tq arm. In that order. Not saying buy them all at once, but try the relocation brackets first, if that dosent help move onto the next.
Old Sep 9, 2006 | 12:21 PM
CW00BlackTA's Avatar
That's what I did but it didn't stop until after the torque arm.
Old Sep 9, 2006 | 12:46 PM
Studytime's Avatar
100% agreed.
Ben T.
Old Sep 27, 2006 | 08:12 PM
meatfoam's Avatar
$60 airbags did the trick for me
Old Sep 28, 2006 | 09:48 AM
FirebirdWS62K1's Avatar
I had wheel hope pretty bad. Just put in some LCA's and did the TA and PHB. GONE! If you don't plan to lower the car get a non-adj TA it'll save you a nice chunk of money. Also if you haven't lowered the car skip the LCA reloc brackets. You can always add them later.
Old Sep 28, 2006 | 11:07 AM
Studytime's Avatar
I think LCAR brackets are the best mod you can do for staight line traction. Also, get an ADJUSTABLE TA. You'll be glad you did. I wouldn't buy an aftermarket one unless it was adjustable, but I would buy a non adjustable panhard rod.
Ben T.
Old Sep 28, 2006 | 10:53 PM
bigdsz's Avatar
I had terrible wheel hop, welded on relocation brackets, problem solved.
