torque arm/saftey loop question
Old Sep 13, 2006 | 08:11 PM
THE LAST Z's Avatar
Default torque arm/saftey loop question
I want to get a tunnel mounted torque arm with a front loop. The only problem is if I get the front loop it won't clear the factory y-pipe. I know i will need a saftey loop anyway. If I order the torque arm with out the loop, How do I add a loop later when I change my y-pipe?
Old Sep 13, 2006 | 08:17 PM
RrCoX22's Avatar
you can either try a relocated TA otherwise you would have to weld one on as they're welded onto the crossmember
