C5 brakes question
The calipers are a direct swap. The rotors are not. I believe the fbody and c5 rotors have different spacing and different parking brakes so its not a direct swap. Also, as you'll see in the link, you have to use a c5 anti rattle clip on each of the rear calipers and it MAY require slight modification to clear the rotors. All other fbody hardware is interchangable. Im doin the swap this weekend so i'll let you know if I run into any problems
http://www.frrax.com/rrforum/index.p...pic=4105&hl=c5
TEX02SS Let us know how the swap goes. I have the front ZO6 brakes ready to go on, but I was wanting to do the rears also.
Thanks guys
I will get some pics up and everything after saturday night
with the stock lt1 pieces
with the stock lt1 pieceshttp://www.napaonline.com/masterpage...are+Kit+-+Rear
