LCA Relocation Brackets
Old Sep 16, 2006 | 01:29 PM
BrianC98Z28's Avatar
Default LCA Relocation Brackets
They are suppost to help the 60ft times, but does anyone have any before and after times to see if they do actually help? Im just curious. Thanks
Brian
Old Sep 16, 2006 | 04:09 PM
UMI Performance's Avatar
Hello Brian,
On a consist car we can usually knock a tenth off a 60' time. Results and times will vary depending on driving ability, current set-up and engine power.. every set- up is different. We do however get tremendous results from these and I highly recommend them as one of the best traction modifications for very inexpensive.
If I can help anymore please ask. Thank you!
Ryan
Old Sep 16, 2006 | 04:11 PM
Ryan which position on the brackets do you reccomend for the best results?
Old Sep 16, 2006 | 04:15 PM
On a more drag oriented vehicle we always run them in the lowest hole setting, if handling a concern then you want the control arm to sit more parallel to ground so depending on vehicle height either location can work. I do however just recommend trying both settings to see which works best for you.
Hope that helps
Ryan
