How to get ABS working?
Old Sep 27, 2006 | 11:54 PM
Gun5's Avatar
Default How to get ABS working?
I got a new rear and lost ABS.. I was wondering how I get TCS to work the car never had it..
Old Sep 28, 2006 | 01:54 AM
ChicagoTransAm's Avatar
Need more info... what type of rearend? Did it come with ABS provisions? If it never had TCS, you can't really add it without quite a bit of work...
Old Oct 1, 2006 | 10:41 PM
Gun5's Avatar
flashes TCS when i turn on the guages how do I check if it ever had TCS?? the rear is a series 2 3.73 richmond w/ girdle
Old Oct 2, 2006 | 01:13 AM
Do you have a TCS switch? If not, then you didn't have it. On a 94, I think it's right behind the shifter. Should be a performance button (firmer shifts) and a button for the TCS to the *right?*
Old Oct 2, 2006 | 01:46 AM
BirdmanLS1's Avatar
why would the tcs flash at startup if we dont have it? I dont have the switch either, but then again i havent seen any signs of TCS on my car... so i prob dont have it either, but why would the light flash at startup?
Old Oct 2, 2006 | 07:39 AM
MeentSS02's Avatar
Kleeborp the Moderator™
If you have no ABS, then you don't have a way to use TCS as they use the same sensors.
