Upgrading to LS1 brake system.
Thanks, Dave
I don't think I'd upgrade the rears. That will just add rear brake bias which most F-bodies don't need. If you do want to upgrade the rears then I think you need the rear brakets as well since the mounting points are not the same.
Jason S.
But just to brush up here, just the calipers, a new set of LS1 rotors and the spindles and I should be set correct?
