brake help
Old Oct 16, 2006 | 07:48 PM
ls1king's Avatar
Default brake help
i just replaced the front rotors, pads, and calipers on my camaro...after dealing with a seized caliper and a bunch of other bs my brakes still arent working right....we bled the system a couple times and the pedal is still goin to the floor...if i pump it a few times the pedal gets hard but then goes right back to soft....any ideas what the problem is and should i try bleeding them again?
Old Oct 17, 2006 | 09:58 PM
YouCantCmyZ28's Avatar
does the pedal get hard before you start it up and then goes soft once you start it, and how are you bleeding your brakes?
Old Oct 17, 2006 | 10:03 PM
Foxxtron's Avatar
Did you reset the ABS module? If not, you might have air trapped in there.
Old Oct 17, 2006 | 10:38 PM
ls1king's Avatar
i figured it out! thanks anyways!
Old Oct 19, 2006 | 02:16 PM
VIP1's Avatar
Copy & Paste Moderator
what was the problem?
