Koni ?
I removed the front passenger shock assembly and removed the shock and perch. I then reinserted that on to the new koni sa. Well when I tighten down the perch the rubber boot on the perch goes over the adjustment. Do I need to cut this or what? Thats not the bad part though. On the driver side I took off the orginal shock and compressed the spring and took off the bolt on the perch and tried to take off the perch only to find out that the rubber has siezed onto the shaft.
I have no clue on how to remove it now besides buying a new perch and cutting the shaft to get the spring on. Is there any other suggestions? I didnt the koni's would be this hard. Also I hade to grind off the last couple of threads on the perch bolt because I couldnt get the bolt off because of rust.-Brandon
I'm not sure why you'd change the spring perch, the one on the Koni's is all you need. And your dust boot simply isn't clipped on the to upper hat properly. As for the rusted mount. You get to buy a new one. Even if you get it off the shock by cutting the old shock rod, the rod will still be stuck in the mount. This is why you should use anit-sieze liberally when putting this together, so it doesn't happen again.
Transfered right over to the new setup and works fine. I had several shops say that if it was rusted I was going to have to buy a new mount but with some patience you can get it apart and salvage everything.
-Brandon
