Need Ta Help Asap!
Old Oct 19, 2006 | 07:14 PM
getusum's Avatar
Default Need Ta Help Asap!
We are currently installing a moser 9 inch and bmr ta....problem is ta is up agaiunst the drive shaft tunnel and the 9 inch needs to come over 2-3 inches....any advice/...help is leaving soon
Old Oct 19, 2006 | 11:32 PM
CW00BlackTA's Avatar
I had the same thing happen. I think what I did (been a while) was take the TA off, connect everything else first and then put the TA on last--starting with the rear first. It helped to have another jack to place under the driver side spring perch--to help bring the yoke down. Then I used a cheater bar to position the front and bolt it up.
