Alignment Settings for a Lowered Z28 ???
Thx.
If so, I'd shoot for the following:
-.7 to -1.0 camber (if it will go to -1, if not, make them match at a lower setting)
4.5 castor (as high as 5 is still fine, but most cars will do the 4.5 setting)
0 toe (not in or out)
You can also drag race on this setup with no problems, but it will make the car more lively in corners. Tire wear is still excellent with this setup (I ran it, but with -1.3 camber for several years and tire life was no problem).
My thoughts.
