lowering ws6
Old Nov 4, 2006 | 04:52 PM
adairstransam's Avatar
Default lowering ws6
Has anybody on here ever cut springs to lower and would it hurt the car, i want to lower my car thanks
Old Nov 4, 2006 | 10:25 PM
CW00BlackTA's Avatar
Been done a lot and I did it on mine. Measure the height of your fenders to determine how much lower you want each corner (mine was all fouled up and lopsided from the factory). Then measure the distance you want to lower on each spring while it is loaded. Then remove, cut and replace. Worked great. Make sure you measure and cut the springs at the right ends (one end mates with the body (or strut).
Old Nov 6, 2006 | 05:01 PM
marthastewart's Avatar
did it handle any worse that the factory? What other parts did you need? Keep the factory shocks or did they need to be replaced?
