abs and brake light
Old Nov 20, 2006 | 04:41 PM
orangefun's Avatar
Default abs and brake light
I broke the abs speed sensor on the frond hub. I abs inop light came on, da, but I drove with it like that for like 2 months, then the E-brake light came on, so I checked the fuild, turned the rotors(they were warpped anyway) and put rear pads b/c they were thin. everything looks good now but when you start the car the light is not on but after you drive like 300 ft the brake light comes on? help please could this be related to the abs provlem?
Old Nov 21, 2006 | 06:41 PM
3.4camaro's Avatar
my ABS light and brake light came on a while ago. I doubled over the electrical grounds and it went away.
just a suggestion.
Old Nov 22, 2006 | 05:56 AM
98 SNAKE EATER's Avatar
Put the car on stands, then start it...
Spin one wheel at a time by hand until the light comes on....
The wheel the light comes on with is the sensor you have to check...
Check the plugs and make sure they're clean and dry (my left front plug had P/S fluid leaking all over it)
You can also use this diag page as a reference:
http://www.ls2.com/boggs/brakeswitch...oralwayson.htm
Rick
Aztek T/A WS7 & 70 RAM AIR IV T/A
Moderator @ LS2, FAST LS1, FUELSLUT,
The F-Body Hideout, LS1Turd & ChopperForums
