Do I Need Adjustable Lower Control Arms?
Old Dec 3, 2006 | 02:36 AM
16floz470ml's Avatar
Default Do I Need Adjustable Lower Control Arms?
Hello. I am looking to buy some control arms and relocation brackets for my 98 Z28. I have a Moser 12 bolt and my car is lowered. Do I need the adjustable lca? If so what are the specs for adjusting them? What does it accomplish? Thanks for your time.
Old Dec 3, 2006 | 02:44 AM
94z28L's Avatar
the adjustable LCA's are for centering the wheel in the wheel well front to back, wouldnt be a bad idea with a new rear, being that you're lowered it will help as well as an adj. PHR
Old Dec 3, 2006 | 02:53 AM
Well right now I have the SLP boxed lca with poly bushings. I also have a single adjustable panhard rod from RaceTech? Everything is centered pretty well. The parts were on the car when I got it. Are these parts that I have any good? I was looking to upgrade.
Old Dec 3, 2006 | 02:56 AM
94z28L's Avatar
poly bushing have a slight tendency to bind up some but they do alright, rod ended control arms are ideal. the set up will work tho
Old Dec 3, 2006 | 06:00 AM
mitchntx's Avatar
94z28L nailed it, though. Adjustability is a by-product of using a solid bushing component.
Just because you painstakingly measure and get the rear wheel perfectly centered in the wheel well, doesn't mean the car is tracking straight and square.
